Possible errata on KL25 Reference Manual
danielcolon
Hello".
I've been trying to configure the PIT Module changing the registers manually following the KL25 Reference Manual (KL25P80M48SF0) it didn't work, so I look at the code in Kinetis SDK and I realize the bits numbers on the Reference Manual tables were backwards. I mean, the bit 0 appears as bit 31 on the Reference Manual.
After configuring the registers with bits as they should be, the PIT module works fine.
Is the Reference Manual wrong? or I missed some note that indicates this backwards convention?
Note: I don't sure if this question goes here.
mjbcswitzerland
Specialist V
All of the PIT registers in the KL25 user manual are numbered incorrectly.
They should count 31...0 rather than 0...31.
As far as I am aware this error is limited to the PIT section of only that manual - all other manuals seem to have it correct.
Mark
Robin_Shen
Sorry for the inconvenience. I have report this issue to our document team.
Robin
mjbcswitzerland
Specialist V
Mark
danielcolon
Thank You!
Wich other manuals do you know about the KL25Z?
Regards.
Daniel.
mjbcswitzerland
Specialist V
I meant all other manuals to other parts (eg. KL26, KL27 etc.).
Mark
