LPC Xpresso 11c24 CAN extended not working
sridharan
I am using LPCXpresso (11c24) board for CAN communication, I am able to transmit standard ID , however when I try to transmit extended ID ,I find no response, I am using the demo sample codes . Can any one help . PFA
Below is the code snip where I suspect demo code problem.
id = id & _EXT_FORMAT;
LPC_CAN->IF1_MSK1 = (id & _MSK1_MSK);
LPC_CAN->IF1_MSK2 = (id >> 16) | _MSK2_MXTD;
LPC_CAN->IF1_ARB1 = (id & _ARB1_ID);
LPC_CAN->IF1_ARB2 = (id >> 16) | _ARB2_XTD | _ARB2_MSGVAL;
Original Attachment has been moved to: CAN-Stepper-LPC11C24-master.zip
Original Attachment has been moved to: CAN.zip
jeremyzhou
Hi sridharan TechM,
I've replied in the CAN Extended ID not able to receive
TIC
