I need to know how can i start working with the board, i have Windows PC and i connected the RS232 to the board but i can't understand how to send a messages and get response.
Someone can help me and give me tips how to begin?
Yoni
Hello Yoni,
Please review the application note below. This application note shows how a host can control, setup, read and write to any I2C-bus devices through this UART-to-I2C controller.
AN10397 - How to use the SC18IM700 to control any I2C-bus device.
I assume you are using the OM6272 evaluation board. Please find the schematic attached to this response.
I recommend to use the material provided in order to create your first example.
I hope this information helps.
David
Hi David,
Thank you for your help, i found the attached schematic very useful.
The reason why i need a code sample is because i'm new in the embedded programming and i don't fully understand how to start writing the code for the board and how to communicate with it from PC with RS-232.
I've already read the guide you attached, but i'm trying to find a real code example...
Thanks!
