About the power sequence of VDD, VDD (PVDD) and VDD (TVDD)
yasushihasegawa
Dear All,
We use CLRC663, MFRC631, MFRC630, SLRC610.
Please tell me the power sequence of VDD, VDD(PVDD) and VDD(TVDD).
The data sheet has the following description.
     VDD(PVDD) must always be the same or lower voltage than VDD.
By the above, I understood the sequence of VDD and VDD (PVDD).
However, VDD (TVDD) does not describe constraints with VDD.
Question:
Is it OK to supply power to VDD (TVDD) when VDD power is supplied or when power is not supplied?
Yasushi Hasegawa
weidong_sun
Hello Yasushi,
Sorry for my late reply!
Generally, PVDD & VDD are the same power, so they are the same time.
TVDD can be supplied late.
that is : PVDD(VDD
Simultaneously)--->TVDD
Weidong sun
weidong_sun
Hello Yasushi,
that is : PVDD(VDD
Weidong sun
yasushihasegawa
Dear Wigros Sun,
Thank you for your answer.
Yasushi Hasegawa
weidong_sun
Hello Yasushi,
    See the diagram, please!
I collected it, hope it can help you!
Weidong
yasushihasegawa
Dear Wigros,
I'm sorry to bother you when you are busy, but can you answer about the following?
However, what I want to know is the Power sequence, that is, the order.
I'm sorry to bother you, but please let me ask you the following question again.
Yasushi Hasegawa
yasushihasegawa
Dear Wigros,
Thank you for your prompt response.
Yasushi Hasegawa
