It's possible to switchable band with OL2385
javierhernande1
It's possible to switch the band with a button? With OL2385. Or I have to make a circuit for each band.
7Segment Led it would be to see the selected band. (yellow square part is a touch button).
This is an idea I made yesterday.
  • RF
estephania_mart
Hello Javier,
You can find the Programmers Guide, page 14, that there is a function called
SF_ChangeNetworkStandard ( sf_drv_data_t _ drvData, sf_net_standard_t standardSel )
I recommend you to check it out and see if it works for you.
Estephania
javierhernande1
Thank you but where I can find that programmer guide?  I don't find it here.
estephania_mart
When you download the software package it is under the following path
<installation path>\Sigfox_SDK_SW\Sigfox_SDK_SW\Programmer_Guide
Estephania
