I need to calculate power dissipation for the mpc5777c chip. Does anyone know if there excel spreadsheet for that created by manufacturer?
Does anyone know what is typical power consumption of the part in watts?
This is really not a question :smileyhappy:
If you know the current consumption and the voltage of micro (all is specified in datasheet)
Then just:
P = U * I
But usually it is around 1W.
You can have either 3.3V or 5V. See the Datasheet below
and
P = (3.3 or 5V ) 1.35 = .... but this is worst case. Typical will be much lower.
Peter
Spreadsheet for MPC5777C is not available.
This is usually done for microcontrollers which are targeted for low power mode operations.
Which is not the case of MPC5777C.
Peter
