MPC5604S global variable initialization issue
akhilprasad
I am using MPC5604S controller and Eclipse based code warrior. During execution the global variables are not getting initialized properly. Can u guide us to solve this issue ?
davidtosenovjan
Could you describe the issue more in detail? How it is improperly initialized? Thanks
akhilprasad
The issue is solved now. The linker file was modified according to the application. In the linker file .data section was not properly mapped to the address because of this the global variables were not properly getting initialized. Thanks.
