floating licence forcing to use only one specific licence for a specific PC ?
cant
Dear support, if a customer has 2 floating licences, 1 Standard and 1 Professional on the same server with FlexLM and wishes to buy anther one Basic (CWP-BASIC-FL), is possible to force this license to be used only from a specific PC leaving the other licences free for other PCs on the network ?
Thanks a lot
Antonio
stanish
Hello Antonio,
There is an option #2:
Customer can buy Node-locked license just for the specific user.
When the development is done they can convert this node-locked license to a floating one.
This cannot be converted on nxp.com account but they will need to contact our licensing team via a support ticket:
 https://community.nxp.com/docs/DOC-329745
Stan
stanish
Hi Antonio,
What about configuring two floating license instances on this server each listening on a different port.
First instance will contain 1 Standard + 1 Professional; Port xxx
Second instance: 1 Basic only; port yyy
Now the client configuration for one specific PC will use port yyy whereas all other client will use port xxx.
Would it meet the customer expectation?
Stan
