fw_setenv is not working
Question asked by Karthikeyan Raju on Apr 18, 2017
Latest reply on Aug 29, 2018 by Dave Bush
Hello All,
I am using sabre-sd board and imx6q yocto bsp. I am trying to set environment from user space. I have generated fw_printenv and fw_setenv. fw_printenv is working perfectly.
I can able to set environment using fw_setenv and i can able to view it using fw_printenv from userspace.
But my problem is that, if i reboot the board I cant get the changed environments done from user space.
I have tried this commands also,
echo 0 > /sys/block/mmcblk2/force_ro
echo 1 > /sys/block/mmcblk2/force_ro
I have enclosed my patch files also.
Need Help to resolve this issue.
Thank you.
Original Attachment has been moved to: env_config.patch.zip
Original Attachment has been moved to: env.patch.zip
