gNumberOfMinislots and gdNIT
lj250668420
HI.
   I am currently using the flexray communication controler,there is a problem,when i read FlexRay_Protocol_Specification_V2.1_Rev.A datasheet,I don't know how to determine the calculated relationship between gdNIT and the duration of the dynamic segment.
   gdNIT[MT] >= max( adRemRateCalculation[MT]; adRemOffsetCalculation[MT] + adOffsetCorrection [MT] )
   adRemRateCalculation[MT] <= max( 1, ceil( (cdMaxRateCalculation[μT] * gdMaxMicrotick[μs/μT] * (1 + cClockDeviationMax) - (adActionPointDifference[MT] + gdMinislot[MT] * gNumberOfMinislots + gdSymbolWindow[MT]) * gdMacrotick[μs] * (1 - cClockDeviationMax) + gOffsetCorrectionMax[μs]) / (gdMacrotick[μs] * (1 - cClockDeviationMax)) ) )
adOffsetCorrection[MT] >= ceil( gOffsetCorrectionMax[μs] / (gdMacrotick[μs/MT] *
(1 - cClockDeviationMax) - gdMaxMicrotick[μs/μT] *
cMicroPerMacroMin[μT/MT] * (1 + cClockDeviationMax)) )
the duration of the dynamic segment = gdMinislot * gNumberOfMinislots.
the gdNIT contains gNumberOfMinislots,the duration of the dynamic segment also contains gNumberOfMinislots,how could i make sure the gNumberOfMinislots?
thanks
lj250668420
the flexray communication controler is MFR4310RM
