Install Code Warrior Error
zhaoqinsu
When I installed Code Warrior 8.7 ,there is a problem just as in the picture .Now I am very anxious to use this software.
Some one can help me ?Thank you very much !
martin_kovar
from the figure you posted above it looks like you use Windows 7. Unfortunately, Code Warrior 8.7 is supported only until Windows XP and most probably it will not be possible to install this product into this operating system.
About the security notice, it looks like the driver you try to install in not subscribed by any known certification authority (or operating system cannot verify the signature.)
Martin
zhaoqinsu
Codewarrior wroks well now , but I can't open the project copied from another guy ,as that in the picture ; picture2.png
