Is there a procedure for getting the KSDK installed on Ubuntu 17.04 and all the other files needed for developing for the TWR-K65F180M?
K-
Hi Kyle Unice
I hear from a colleague that you problem has been resolved in a case. The problem seams to be related with your tower serial connections and power supply, can you confirm that you problem has been resolved?
If the problem still exists could you explain more your issue? as you can see in the image below, you can download KSDK for linux:
Jorge Alcala
