Peripheral Register View broken after update in S32DS for PPC, Linux Host
yibbidy
Contributor V
I just updated S32DS for PPC on Linux host through the inbuilt Eclipse update method.  I can no longer see the peripher registers.  I'm pretty sure that I used to access it through the "EmbSysRegView 2.0" tab (rather than the "Modules" tab).  Opening the "EmbSysRegView 2.0" tab gives this message:
"Error loading registers data. SVD(XSD) file corrupted or missing"
I can however still view registers referenced in my code by hovering the mouse over the register name in the code.
Any ideas?
Shaun
yibbidy
Contributor V
Hi Martin,
I am using Ubuntu 12.04LTS 64 bit.  I haven't updated for a few months so it may have been a previous update to S32DS PPC v1.1 that's the cuprit.
No I haven't re-installed.  I do have a another linux machine with S23DS PPC v1.1 on it, that I haven't updated, so if I knew where to look for this "corrupted or missing" file I might be able to copy it across.
Thanks, Shaun
martin_kovar
could you please tell me which Linux distribution you use? I would like to test in on my side.
Did you try to reinstall Design Studio? It looks like some error during installation or update file error.
Martin
