Can i use ulink pro jtag debugger with kinetis design studio or codewarrior ?
sameerarvikar
I have got ulinkpro debugger from armkeil ,can i use it with codewarrior for MCU or Kinetis design studio for debugging
Hello sameer,
I'm confirmed with ARM support,  the ULINK adapter are supported by ust uVision,
doesn't support KDS or CW.
And the support devices listed at the below site :
MDK5 Device List
Hope it helps
TIC
Hello Sameer,
 You said KDS, so do you want to develop Kinetis chips ?
  I checked the ULINKpro seems doesn't support kinetis :
maybe I missed something , as to I know little about the ULINKpro, I can  ask the ARM support
for it if your need . And also you can test a simple project on your side .
TIC
