Hello
I devised an easy way to determine the CPU speed using ARM Serial Wire Viewer.
This works with any Kinetis or LPC Cortex-M3, M4 or M7. Assume also Cortex-M23 or 33. No Cortex-M0 (has no SWV)
I posted it here: Application Note 297: Using Serial Wire Viewer to Confirm CPU Speed
This uses eval version of Keil MDK and any ULINK or a Segger J-Link.
Tanks
Bob Boys
ARM
Hi Bob,
Thank you for your input :smileywink:
Soledad
