What is the resonant frequency of this accelerometer?
what is the minimum 3dB bandwidth that is acceptable for production parts?
how much variation in 3dB bandwidth can be expected between the x and y channels?
Hi Dan,
The resonant frequency of the accelerometer is around 4 Khz for X and Y axes. The Z-axis design is over damped and hence does not have a resonant peak. We don't have any data on distribution of this number, so I cannot tell you the minimum acceptable 3dB bandwidth neither the variation you should expect between X and Y axes.
Dario
