Can't run firmware on OM13092 in stand alone
MAPC
Senior Contributor I
Sorry. I think I was not clear in my last message. What I meant to say was that I can't run the firmware out of the debugger, in stand alone.
soledad
Hi Marco,
What is the process you are following to run the program?
Can you debug without issues?
Soledad
MAPC
Yes, Soledad
I'm able to run the code perfectly in debugger, but it doesn't run in stand alone.
Carlos_Mendoza
Hi Marco,
Please see my reply on your other thread and let me know if it helps:
Best Regards!
Carlos Mendoza
Technical Support Engineer
