Kindly confirm me, does LS1043A I2C port supports PMBus or not?
The LS1043a I2C can be used as PMB bus using software implementation for PMB bus. See the following document from TI for using PMBus Over I2C:
http://www.ti.com/lit/an/sprabj6/sprabj6.pdf
PMB bus is bus based on SMB bus.
See also the following page about difference between I2C bus and SMB bus:
https://www.maximintegrated.com/en/app-notes/index.mvp/id/476
Pavel Chubakov
