how do I add column markers
jacewalton
in kinetis IDE how do  add column marks such as in the picture below
thanks
this is from an different IDE
BlackNight
Hi Jace,
there is code collapsing/folding (see Eclipse Folding | MCU on Eclipse ), but not with such lines.
What you are asking for is discussed in Vertical line between matching curly braces for java in eclipse - Stack Overflow , and it mentions the Plugin IntentGuide (IndentGuide ) which does what you wants, but I have not tried it.
I hope this helps,
Erich
