adrianraileanu
Regaining debug after reconfiguration of SWD pins
Discussion created by adrianraileanu Employee on Mar 30, 2017
I just want to share a possible solution in case you have "bricked” an S32KxxxEVB by running a code that reconfigures the debug pins (SWD_CLK, SWD_DIO) to other functions.
All you need is an external probe - P&E Multilink and the P&E Recover utility.
The procedure is the same as described for Kinetis devices in Erich Styger's blog:
https://mcuoneclipse.com/2013/06/16/bricking-and-recovering-frdm-kl25z-boards-reset-swd-clock-and-low-power/
Thanks to a customer for pointing to that solution.
(I've not tried it yet, I'll update when checking it on my own board)
