Debug Variable Expression View Data Format
Question asked by David XY Zhou on Mar 30, 2017
Latest reply on Mar 31, 2017 by David XY Zhou
I have K60Tower board: _K60P144M150SF3RM, with MQX4.2 version, and CodeWarrior 10.6.4 Version
During debug if the program execution is stopped at a break point, hovering mouse over a variable, the debugger will display the value of the variable. But it seems always default the format to string. So it shows unreadable characters for an integer variable. I changed to Hexdecimal as follows:
This is from the webpage: Debugging Variables in Hexadecimal with Eclipse | MCU on Eclipse
But it doesn't have any effect. What have I missed and how to set global default format to hexadecimal ?
Thank you,
David Zhou
