FCCU configuration and sample code for MPC5746R
kiranmuniraju
I need to do FCCU configuration and need to collect the NCF faults.
From the Reference manual I found out that we need to use FCCU_NCF_Sn status register for getting the fault status.
for the same we need to write OP10 into control register and wait for the operation successful.
Is there any sample FCCU configuration done for MPC5746R so that it will be helpful.
Kiran
petervlna
You can find it here:
https://community.nxp.com/docs/DOC-329719
It is common for all MPC57xx devices.
Peter
