Renjith R
MPC 5746 stack overflow registers
Discussion created by Renjith R on Mar 29, 2017
I am doing a project with MPC 5746.I need to monitor the stack overflow in it.In data sheet DBCR4 register 24 to 27 bit is set to 1000 then DAC1 address comparison are used for stack limit checking.but not get a clear idea.Any one can suggest,there is any perticular registers use to monitor the stack overflow or anyother different methods are used for stack monitoring and overflow detection?  ...thank you
