Rigado R41Z debug problem
wojtek_84
I have Rigado R41Z development kit which is based on KW41Z. I have problems with running BLE examples from Kinetis KW41Z Connectivity Software under KDS 3.2. I can debug all driver examples and demo apps (e.g. bubble) but when I try to start debug session for BLE example (e.g. beacon) I get an error:
Error in final launch sequence
Failed to execute MI command:
-exec-run
Flashing works fine. Jlink is recognizing the boeard correctly.
I compered the debug configuration but I connt see any difference between BLE and none BLE examples.
I would appreciate any help.
Regards.
msjadem
Wojciech,
We noticed the same issue here at Rigado.
Make sure to check for updates in KDS. If you receive an error like " Unable to read repository at https://gnuarmeclipse.sourceforge.net/updates/content.xml", you can still download that repository in a zip file and manually update.
Kyla Marino
Rigado Support Engineer
pavel_krenek
Hi Wojciech,
first you would check low power mode settings. It looks after the programming the mcu goes to sleep mode and disconnect the debugger.
Pavel
