question about "fsl-image-kernelitb" in ls1043ardb-32b
Question asked by uncoldice chen on Mar 28, 2017
Latest reply on Mar 28, 2017 by uncoldice chen
I am using the latest SDK-2.0-1701.
I tried to build ls1043ardb-32 with target "fsl-image-kernelitb"
According to the document, the built FIT image comprises the Linux image, dtb and rootfs image.
But, when built finished, and I deploy the itb file to the board by following steps (referred to chapter "4.4.9.9.1")
=>setenv bootargs ‘root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 console=ttyS0,115200’
=>saveenv
=>tftp a0000000 kernel-fsl-ls1043a-rdb.itb
=>bootm a0000000
I met the issue that kernel stuck. From the log, seems the ramdisk is missing.
Please have a look at attached log and give suggestions how to correctly deploy the ramdisk.
Thank you very much.
Original Attachment has been moved to: ls1043a_32b_startup.txt.zip
