iMX6SoloX - fast authentication - uImage signing.
Question asked by ARKADIUSZ KARAS on Mar 28, 2017
Latest reply on Apr 2, 2017 by Victor Linnik
Hello all,
O have a question regarding secure boot on iMX6SoloX processor, in fast authentication mode.
I have manage to boot successfully signed u-boot image in fast authentication mode.
I have generated 4 SRK keys for HAB, as described in MX6UL HAB (High Assurance Boot) https://community.nxp.com/docs/DOC-275249.
For signing u-boot I use following file:
#Illustrative Command Sequence File Description
[Header]
Version = 4.1
Hash Algorithm = sha256
Engine = ANY
Certificate Format = X509
Signature Format = CMS
[Install SRK]
File = "crts/SRK_1_2_3_4_table.bin"
Source index = 0
[Install NOCAK]
File = "crts/SRK1_sha256_2048_65537_v3_usr_crt.pem"
[Authenticate CSF]
[Unlock]
Engine = CAAM
Features = RNG
[Authenticate Data]
# Key slot index 0 used to authenticate the image data
Verification index = 0
Blocks = 0x8bfff7d0 0x00000000 0x00058000 "u-boot-pad.imx"
Now, I want also to check signature for uImage, but I want to use different key for that.
I tried with following configuration first:
[Header]
Version = 4.1
Engine = ANY
[Install SRK]
Source index = 0
[Install NOCAK]
[Authenticate CSF]
[Unlock]
Engine = CAAM
Features = RNG
[Authenticate Data]
Blocks = 0x80810000 0x0 0x385020 "uImage.pad.ivt"
It works properly with "SRK1_sha256_2048_65537_v3_usr_crt.pem" key, but if I try to use different certificate (i.e. SRK2_sha256_2048_65537_v3_usr_crt.pem) I always got signature check failure.
So my question is - is it possible to sign uImage with different key than u-boot in case of fast authentication mode ?
Arek Karaś
