I am evaluating the solution of ZigBee 3.0 in JN517x platform but I have difficulties in compiling the solution in LPCXpresso for JN-AN-1216 example.
On compiling the original source code I got the following error during the linking process:
lto-wrapper.exe: fatal error: c:\NXP\LPCXpresso_8.2.2_650\lpcxpresso\tools\bin\arm-none-eabi-gcc.exe returned 1 exit status
compilation terminated.
c:/nxp/lpcxpresso_8.2.2_650/lpcxpresso/tools/bin/../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/bin/ld.exe: error: lto-wrapper failed
collect2.exe: error: ld returned 1 exit status
make: *** [ZigbeeNodeControlBridge_JN5179_FULL_FUNC_DEVICE_1000000.elf] Error 1
A copy of all the messages on the build console has been attached.
All 4 configuration I have already tried but none of them can be built.
I have read through the document of the application note AN - 1216 but still haven't found the way out.
I have also tired other projects and most of their configurations were successfully built.
JN-AN-1218
JN-AN-1219
but the same problem happens in some of the those configurations, for examples the EN_SWITCH in JN-AN-1219 .
Could someone give me hints to fix the issue?
Thanks for your attention.
Trevor
Original Attachment has been moved to: Console.txt.zip
Hello Trevor,
For JN5179 ZigBee 3.0, you should install and use LPCXpresso 7.9.2_493. (several documents have described this). See below for my building console.
Also for the least problem, unzip the sample project to default work space. Uncheck "copy projects into workspace" while importing.
Good Luck,
Benjamin
