LPC4088 QSB + LPCXPRESSO V8.2.2 + LPCLINK2 error
Question asked by Pascal REYGNER on Mar 27, 2017
Latest reply on Mar 28, 2017 by LPCX presso support
the LPC4088 QSB card is working correctly when using mbedCompiler (programming software / reset / soft working correctly).
when i connect EmbeddedArtists LPC4088 QSB Card + LPCXPRESSO V8.2.2 + LPCLINK2, the following failure appears on console debug message when trying connection with debugger :
" LPCXpresso RedlinkMulti Driver v8.2 (Sep 5 2016 10:12:38 - crt_emu_cm_redlink build 725)
Found chip XML file in C:/Users/preyg/Documents/LPCXpresso_8.2.2_650/workspace/lwip_tcpecho_freertos/Debug/LPC4088.xml
Failed on connect: Ee(36). Could not connect to core.
No connection to emulator device ".
ERROR REPORTED BY TARGET :
02: Failed on connect
31: No connection to emulator device
i have tried proposed solution on this blog : Regaining debug access to target MCU
using buttons SW1 + SW2 or changing  "vector cache", it is still don't work
DO YOU HAVE ANY SOLUTION?
thanks a lot
