LPC1114 interrupt issue
keny
I made a simple code to test the interrupt on LPC1114 but it doesn't enter the routine.
the code:
#include "LPC11xx.h"
volatile int count=0;
void TIMER_32_0_IRQHandler(void) {
   LPC_TMR32B0->IR = 1; //reset flag
   count++;
   if (count == 44000) {
      count = 0;
   LPC_GPIO1->DATA ^= (1<<6);
int main(void) {
   LPC_SYSCON->SYSAHBCLKCTRL |= (1<<9);//enable clock on TC32B0
   LPC_TMR32B0->MCR = 3; //enable interrupt + interrupt when TC = MR0
   LPC_TMR32B0->MR0 = 1091; //match register
   LPC_TMR32B0->IR = 1; //interrupt on MR0
   NVIC_EnableIRQ(TIMER_32_0_IRQn);//enable interrupt
   LPC_TMR32B0->TCR = 1; //enable timer
   LPC_GPIO1->DIR |= (1<<6);
   while(1) {
I don't understand where i am wrong.
Badman
Check this code:
void TIMER32_0_IRQHandler(void)
     if ( LPC_TMR32B0->IR & 0x01 )     // check interrrupt from MR0
       count++;
int main(void) {
   LPC_SYSCON->SYSAHBCLKCTRL |= (1<<9);     //enable clock on TC32B0
   LPC_GPIO1->DIR |= (1<<6);     // P1.6 as output
   while(1) {
        if (count >= 44000)
            count = 0;
keny
I try
void TIMER32_0_IRQHandler(void) {
but it doesn't work too
jeremyzhou
I'd highly recommend you to refer to these periph_blinky demo which are involved in the LPCOpen library.
LPCOpen library:
Ping
