CROSSBAR IN MPC5643L
admin
Specialist II
I am analyzing the Crossbar module in MPC5643L. So, Suggest me how to start with the module and what is the procedure to start coding with the module and what is the process need to be done. I also need some examples for XBAR in MPC5643L.
davidtosenovjan
Hi, I could recommend to see following thread:
What is the advantage of Crossbar Switch
Easiest way (and quite common) of XBAR configuration to leave XBAR default setting.
