Does the LS1012ARDB support SD UHS-I?
Question asked by Zaid Albassam on Mar 23, 2017
Latest reply on Mar 27, 2017 by Pavel Chubakov
Iam trying to check the performance of the SD card on the LS1012ARDB, using a Sandisk Extreme Pro UHS-I sd card.
When I check the AUTOCERR_SYSCTL2 register of the esdhc1 I see the UHSM field is set to SDR12 (with and without data transfer):
root@OpenWrt:/mnt# devmem 0x156003c
0x00000000
The manual says that the LS1012A itself supports SDR104. My question is, does the RDB supports UHS-I mode? if yes how to switch the Linux driver to use it?
Thank you,
Zaid
