LPIT with Fast IRC clock
adrianwenger
When i use this LPIT Options
the timer will not work correctly...
-- LPIT timer Settings in timer module
-- the main module
I use the FIRC as MCU clock and want to use it also al peripheral clock for LPIT...
But unfortunately wether the LED nor the A11 Port is toggling.
What is wrong here?
BR,
Adrian
danielmartynek
Please have look at the attached project.
I have done a few changes in your code, it should work.
danielmartynek
adrianwenger
Hi Daniel,
thanks now it works!
Adrian
