Bita Sobhani
is address map built automatically?
Discussion created by Bita Sobhani on Jul 28, 2008
Latest reply on Aug 5, 2008 by Mads Westergreen
Hi all
I know that address map is automatically built in coordinator when each node joins the network.
Is this true for end devices and routers?
I need to built address map for every node in the network so that it holds specific nodes addresses.
have I do it myself or the address map is built automatically in end devices?
If I have to built it, when should I use addr_req for example?
THANKS
