regarding the power down current on PA5180
jasonz
I am comparing NXP's  NFC front-end solution with AS3911B for our EMV-compliant payment devices.
The Ipd (typical) is 15uA , but it is only 0.7uA based on the AS3911B. can you advise  if there is a way to make  PA5180 drop  lower current such as 1uA in power down mode?
Also , do you mind proving me a detailed comparison comparing with AS3911B in terms of power consumption, RF performance and so on?
Appreciate your reply!
Jonathan_Iglesias
Dear Jason Zhang,
I was looking in the data sheet and unfortunately this  current values you need can not be reached.
Jonathan
