How to use CsIo1.c get data from terminal on PC
abneryen
Dear sir
I want to send some data via terminal on PC to MCU(MKE06P80M48SFORM), but I don't how to use CsIO1.c ( CodeWarrior generate) I can receive data via terminal on PC by printf.
Could  you tell me how to use CsIO file? Or tell me another method to send data via terminal on PC to MCU .
Thanks a lot
Abner
Hello Abner,
- If you want use printf to send date to PC , only need add the Processor Expert componnet "ConsoleIO",
then  configure it , about the detail steps please refer to the attached DOC,only need check the one part
of :
Please pay attention on which UARTport do you used on your board .
Hope it helps
Alice Yang
