Jennet-IP traps
Jennet-IP traps
balazsring
Hi, we are using Jennet-IP for medium-sized networks (50-150 nodes). We would like to have event-driven communication from the nodes to the boarder-router based on traps associated to variables, however, it seems to have bugs as after a gives time events are not sent any more. Please suggest how to overcome this issue or what tools can we use to overcome this issue.
Thank you!
limcb
Do you have packet sniffer ? Can you check if traps are not being sent over the air ?
I thought the stack only supported up to 16 traps maximum ?
