TWR-K53N512 in IAR-6.10.5: debug port undetected?
jerrylian
In IAR Workbench, I followed the "TWR-K53N512 Quick Start Demo Lab Guide" step by step!
However when I hit "Download and Debug", the PEMICRO Connection Manager shows:
Interface: USB Multilink, Embedded Multilink, or Embedded OSJtag
Port: Undetected. Disconnect/Connect USB cable. Click Refresh List.
Anybody know the solution?
Thanks!
Jerry
kerryzhou
Hi Jerry,
IAR-6.10 is really very older, I think maybe in that IAR version, it doesn't support  the OSJTAG.
Normally, we recommend the customer to use the new IAR reversion.
  About the MQX quesiton, please create a new post, our MQX engineer will help you to solved.
I  am just the bare mental engineer.
Kerry
jerrylian
Hi, Kerry:
Thanks, I have downloaded and tried the project: KINETIS512_SC\KINETIS512_SC\build\iar\gpio
* Under IAR-8.10: your project works well!  (I need to upgrade OSBDM/OSjtag firmware)
* Under IAR-6.10: I still got the error:            (I need to use original OSBDM/OSjtag firmware)
----- Interface: USB Multilink, Embedded Multilink, or Embedded OSJtag
----- Port: Undetected. Disconnect/Connect USB cable. Click Refresh List.
So, we can conclude now:
* IAR-8.10 is NOT compatible with MQX RTOS.
* IAR-6.10 does NOT recognize OSBDM/OSjtag port
Maybe there is something wrong with my operations, but hope NXP team can fix the bugs.
Thanks again!
Jerry
kerryzhou
Hi Jerry,
Kerry
jerrylian
Hi Kerry:
Surely I will stick with new version IAR. And one NXP guy is dealing with "MQX" issue in a separate post.
Thanks!
Jerry
kerryzhou
Hi Jerry,
   If this question is solved, please help to mark the correct answer to close this post.
  Thank you!
Kerry
jerrylian
Thanks Kerry:
I just did. I am new to this forum, and don't know all the tricks yet.
Jerry
jerrylian
Hi, Kerry:
Thanks for your detailed instructions!
I think I have installed PEMicro driver already, as I installed everything from accompanying-CD in kit TWR-K53N512. And it works well in CodeWarrior, but not in IAR-6.10, weird!
Actually I have already tried IAR-8.10, but when I open the workspace, I got another error:
"C:\iar-mqx\IAR8\arm\plugins\rtos\MQX\MQXRtosPluginARM.dll": the specified procedure could not be found."
Have you ever encountered this error in IAR?
Thanks!
Jerry
nitinhrish
IAR v 8.10 is incompatible with MQX, another proof here: https://community.nxp.com/thread/446933
kerryzhou
Hi Jerry Lian,
  Please try my attached TWR-K53 project.
  Folder:KINETIS512_SC\KINETIS512_SC\build\iar\gpio
  Your problem seems caused by your mqx project, so please try the bare metal project at first, just like my definition in the last email.
Kerry
kerryzhou
Hi Jerry Lian,
    1, Please download the PE driver from this link and install it:
http://www.pemicro.com/downloads/download_file.cfm?download_id=53
    2. You should better download a new IAR version, 6.10 is very old now, my IAR version is  7.8.
    3. Please configure it like this :
Please try it on your side.
If you still have question, please let me know!
Kerry
