Can you, please, explain, which endian type (big/little) should be used for Discovered Bad Blocks Table (DBBT) on i.MX6
processors? Mainly we are interested in how bad block numbers are stored. (See chapter 8.5.2.4 in i.MX6 reference manual (doc. ID IMX6DQRM).
Kind regards,
Frantisek
Solved! Go to Solution.
Hello Frantisek,
The i.MX6DQ uses 32bits Little Endian for the DBBT.
Hope this clarifies.
Jaime
Hello Jaime,
This answers my question. Thanks a lot!
Have a nice day,
Frantisek
Hello Frantisek,
Jaime
Hello Jaime,
I do have another question:
Can you, please, explain the usage of FCB structure members PagesInFirmware1 and PagesInFirmware2?
What can we expect if real firmware size is e.g. 70 pages, but these members are set to 68?
Frantisek
