I am trying to use spread spectrum for the i.MX7D by playing with STOP values according to reference manual formulas but get unreasonable measurements in spectrum analyzer
What is the range that should be set in STOP value?
Since you use unreasonable STOP value, you see unreasonable result on the PLL output. In your case, the formally calculated spread spectrum range exceeds the PLL output frequency, that has no meaning. For normal operation, the spread spectrum range must be no more than some units of percents of target output frequency. So, try to use some more realistic STOP value that meets the formal calculation criteria.
Artur
