Hi everybody
May I ask what is the purpose of the code in line 183? Can u explain the working theory in detail? Or is there any document for instruction, thanks.
You can find more information about how to set up the burst length through the mode register in the SDRAM memory on the section 23.8.5 in the UM:
http://www.nxp.com/documents/user_manual/UM10503.pdf
Hope it helps!
Carlos Mendoza
Technical Support Engineer
