W25Q16DW Flash Programmer for ls1012a
Question asked by ruslanfilipovich on Mar 15, 2017
We are building a custom board with an LS1012a processor and an attached W25Q16DW QSPI flash.  As a programming algorithm, we used W25Q64F.xml. We added flash device (see attach: W25Q16DW.xml) and fixed the target initialization script (see attach: aktau-target-init.script). In the current moment "dump"  command from device is working, but erase and program command not working. See this image:
Below is the flash connection:
Please, help me fix this problem
Original Attachment has been moved to: W25Q16DW.xml.zip
Original Attachment has been moved to: aktau-target-init.script.zip
