what' wrong with tftp
Question asked by longqi luo on Mar 13, 2017
Latest reply on Mar 15, 2017 by longqi luo
hello, I am using P1023 and I designed ethernet refered to P1023RDB. now some problem happended on tftp function as below, you can see  MIB Registers: Transmit and Receive Counters , could someone tell me what/s wrong with my board?
U-Boot 2011.12 (Mar 12 2017 - 11:21:24)
CPU0:  P1023E, Version: 1.1, (0x80fe0011)
Core:  E500, Version: 5.1, (0x80212151)
Clock Configuration:
       CPU0:400  MHz, CPU1:400  MHz,
       CCB:266.667 MHz,
       DDR:400  MHz (800 MT/s data rate) (Asynchronous), LBC:16.667 MHz
       FMAN1: 266.667 MHz
L1:    D-cache 32 kB enabled
       I-cache 32 kB enabled
Board: P1023 RDS
I2C:   ready
SPI:   ready
DRAM:  256 MiB
Now running in RAM - U-Boot at: 0ff30000
Now running in function:board_early_init_r(p1023rds.c)Flash: 64 MiB
L2:    256 KB enabled
cpu_init_r() complete !
NAND:  fsl_elbc_nand: address did not match any chip selects
0 MiB
env_relocate() complete !
cpu_secondary_init_r() complete !
EEPROM: Read failed.
eth_getenv_enetaddr() complete !
getenv_IPaddr() complete !
PCIe1: Root Complex of Slot 1, no link, regs @ 0xff60a000
PCIe1: Bus 00 - 00
PCIe2: Root Complex of Slot 2, no link, regs @ 0xff609000
PCIe2: Bus 01 - 01
PCIe3: Root Complex of Slot 3, no link, regs @ 0xff60b000
PCIe3: Bus 02 - 02
pci_init() complete !
stdio_init() complete !
In:    serial
Out:   serial
Err:   serial
cosole_init_r() complete !
U-Boot relocated to 0ff30000
Net:   Fman1: Uploading microcode version 160.0.18
PHY reset timed out
FM1@DTSEC1, FM1@DTSEC2
Warning: failed to set MAC address
eth_initialize() complete !
UT_PPC PowerPC bootloader starting ...
### main_loop entered: bootdelay=3
Hit any key to stop autoboot:  0
=> md ff7e0200
ff7e0200: 00000000 00000000 00000000 00000000    ................
ff7e0210: 00000000 00000000 00000000 00000000    ................
ff7e0220: 00000000 00000000 00000000 00000000    ................
ff7e0230: 00000000 00000000 00000000 00000000    ................
ff7e0240: 00000000 00000000 00000000 00000000    ................
ff7e0250: 00000000 00000000 00000000 00000000    ................
ff7e0260: 00000000 00000000 00000000 00000000    ................
ff7e0270: 00000000 00000000 00000000 00000000    ................
ff7e0280: 00000000 00000000 00000000 00000000    ................
ff7e0290: 00000000 00000000 00000000 00000000    ................
ff7e02a0: 00000000 00000000 00000000 00000000    ................
ff7e02b0: 00000000 00000000 fe03ffff 000ffffd    ................
ff7e02c0: 00000000 00000000 00000000 00000000    ................
ff7e02d0: 00000000 00000000 00000000 00000000    ................
ff7e02e0: 00000000 00000000 00000000 00000000    ................
ff7e02f0: 00000000 00000000 00000000 00000000    ................
=> md ff7e0000
ff7e0000: 08240101 002c0000 02000700 00000000    .$...,..........
ff7e0010: 00000000 00000058 00000000 00000008    .......X........
ff7e0020: 00000000 00000000 00000000 00000000    ................
ff7e0030: 00000000 00000000 00000000 00000000    ................
ff7e0040: 00000020 00000000 00000000 00000000    ... ............
ff7e0050: 00000021 00000000 00000000 00000000    ...!............
ff7e0060: 00000000 00000000 00000000 00000000    ................
ff7e0070: 00000000 00000000 00000000 00000000    ................
ff7e0080: 00000000 00000000 00000000 00000000    ................
ff7e0090: 00000000 00000000 00000000 00000000    ................
ff7e00a0: 00000000 00000000 00000000 00000000    ................
ff7e00b0: 00000000 00000000 00000000 00000000    ................
ff7e00c0: 00000000 00000000 00000000 00000000    ................
ff7e00d0: 00000000 00000000 00000000 00000000    ................
ff7e00e0: 00000000 00000000 00000000 00000000    ................
ff7e00f0: 00000000 00000000 00000000 00000000    ................
=> md ff7e0014
ff7e0014: 00000058 00000000 00000008 00000000    ...X............
ff7e0024: 00000000 00000000 00000000 00000000    ................
ff7e0034: 00000000 00000000 00000000 00000020    ...............
ff7e0044: 00000000 00000000 00000000 00000021    ...............!
ff7e0054: 00000000 00000000 00000000 00000000    ................
ff7e0064: 00000000 00000000 00000000 00000000    ................
ff7e0074: 00000000 00000000 00000000 00000000    ................
ff7e0084: 00000000 00000000 00000000 00000000    ................
ff7e0094: 00000000 00000000 00000000 00000000    ................
ff7e00a4: 00000000 00000000 00000000 00000000    ................
ff7e00b4: 00000000 00000000 00000000 00000000    ................
ff7e00c4: 00000000 00000000 00000000 00000000    ................
ff7e00d4: 00000000 00000000 00000000 00000000    ................
ff7e00e4: 00000000 00000000 00000000 00000000    ................
ff7e00f4: 00000000 00000000 00000000 00000000    ................
ff7e0104: 00007115 40605060 00a1f037 00000800    ..q.@`P`...7....
=> mm ff7e0014
ff7e0014: 00000058 ? 1058
ff7e0018: 00000000 ? q
=> tftp test.txt
Using FM1@DTSEC1 device
TFTP from server 192.168.1.20; our IP address is 192.168.1.4
Filename 'test.txt'.
Load address: 0x1000000
Loading: T T T T T #
done
Bytes transferred = 648 (288 hex)
=> md ff7e0200
ff7e0200: 00000012 0000000d 00000000 00000000    ................
ff7e0210: 00000003 00000000 00000000 00001482    ................
ff7e0220: 000000bc 00000004 00000004 0000000a    ................
ff7e0240: 00000000 000000a8 00000000 00000000    ................
ff7e0250: 00000000 000000a5 00000000 00000000    ................
ff7e0260: 000002d6 0000000b 00000000 00000004    ................
=> tftp test.txt
Loading: T T #
done
=> md ff7e0200
ff7e0200: 00000021 0000001b 00000000 00000000    ...!............
ff7e0210: 00000004 00000000 00000000 00001fb8    ................
ff7e0220: 0000010d 00000009 00000007 00000011    ................
ff7e0230: 00000000 00000000 00000000 00000001    ................
ff7e0240: 00000000 000000e9 00000000 00000000    ................
ff7e0250: 00000000 000000e1 00000000 00000000    ................
ff7e0260: 0000052c 00000014 00000000 00000007    ...,............
=> tftp 1000000 uImage
Filename 'uImage'.
Loading: T T T T T T T T T T
Retry count exceeded; starting again
*** ERROR: `eth1addr' not set
Abort
=> md ff7e0200
ff7e0200: 00000043 0000003d 00000002 00000002    ...C...=........
ff7e0210: 00000006 00000003 00000000 00005d0a    ..............].
ff7e0220: 00000344 0000001e 0000000f 0000002e    ...D............
ff7e0230: 00000000 00000000 00000000 00000006    ................
ff7e0240: 00000000 000002f6 00000000 00000000    ................
ff7e0250: 00000000 000002da 00000000 00000000    ................
ff7e0260: 00000900 00000023 00000000 0000000a    .......#........
=> pri
baudrate=9600
bootargs=root=/dev/mtdblock2 rootfstype=jffs2 rw console=ttyS0,9600
bootcmd=bootm 0xefb70000 - 0xeda50000
bootdelay=3
bootfile=uImage
ethact=FM1@DTSEC1
ethaddr=00:04:9f:02:87:0d
fileaddr=1000000
filesize=288
fman_ucode=0xec000000
gatewayip=192.168.1.1
hwconfig=usb1:dr_mode=host,phy_type=ulpi
ipaddr=192.168.1.4
loadaddr=1000000
netmask=255.255.255.0
serverip=192.168.1.20
stderr=serial
stdin=serial
stdout=serial
Environment size: 467/8188 bytes
