Pressure sensor underwater vehicle
Question asked by Wilmer Ariza on Mar 12, 2017
Hi, I had an application where a differential sensor is required to measure the pressure on two sides of a hull underwater. I know that the mxp sensors are only for air at least you create an air bubble between the fluid and the sensor but in my case, the bubble can scape very easy. Any recommendation in what type of mechanical barrier as a rubber to use? how has silicone gel to be applied to avoid moisture inside of the sensor?
