i.MX6 dual appearance in JTAG chain
joachimhofmann
Dear NXP Team,
we like to understand how a i.MX6 dual  normally and correctly appears in the JTAG chain,
I have a customer with the attached list of devices while only two ICs are actually JTAG connected, one Xilinx CPLD and the i.MX6D processor.
3 instances are presumably associated with the i.MX
1. Freescale/Motorola
2. unidentified ??
3. ARM
Please clarify how the i.MX6D SHOULD appear (how many and which instances) and also advise if the use of a foreign third party JTAG tool could be the cause.
In this case: Which JTAG tools are recommended or approved
With regards
Joachim Hofmann
Hi Joachim
please check sect.7.4 Defining the JTAG chain  attached i.MX6 Hardware Guide
joachimhofmann
Hi Igor,
thanks, but your Reply did not contain an attachment or a link to a document.
The "Hardware user Guide" for i.MX6D makes no mention of "JTAG chain" in section 7.4 (which talks about IBIS model).
Please include a link or the actual document you are refferring to.
With regards
Joachim
Hi Joachim
attachment in red in previous answer (IMX6DQ6SDLHDG.pdf), please click with mouse on it
