We have 1 floating license for CodeWarrior Professional that is currently being used. We just purchased an additional 1 floating license for CodeWarrior Standard. How do I install and use both of these licenses on the server as well as the individual clients? I get a different license.dat file for each one...is here a way to combine them?
Solved! Go to Solution.
Hi Mike,
You need merge the two license to one.
Just copy the second license.dat file content and appended to the first one.
you can edit the license file with notepad.
Jennie Zhang
Hi Mike,
Jennie Zhang
