LS102x: QUICC/UCC UART: Disable hardware handshake
Question asked by konradgräfe on Mar 8, 2017
Latest reply on Mar 9, 2017 by konradgräfe
I was able to activate the UCC UART on the LS1021A-TWR and it is working as expected. However, I could not figure out, how to disable hardware handshaking.
The stty tool does not work (which is not surprising since I did not see the driver handling this flag, but anyway):
root@ls1021atwr:~# stty -F /dev/ttyQE0 115200 -crtscts
root@ls1021atwr:~# echo lol > /dev/ttyQE0
ucc_uart 2402000.ucc: shutdown timeout
And I could not find how that would be set on the register level.
In QEIWRM_V8.pdf chapter 16.4.5 Initializing the UCCs it says
3. Configure the parallel I/O registers to enable RTS, CTS, and CD if these signals are required.
Which implies that it should be possible to disable hardware handshaking. But I did not find what the parallel I/O registers would be for this processor.
Can you help me out here?
