PING is not stable after porting RTCS ,help.
Question asked by yong liu on Mar 7, 2017
After porting the MQX3.7 to  K60MK60DN512ZVLQ10 ,I "PING" to MCU and find that:
1 when connecting K60 to PC in OFFICE ,"PING" is OK ,even UDP is OK .
2 Then bing a switchboard between them,"PING" is not stable, often come to a timeout.
3 connect two PC each at home ,PING is not stable,often come to a timeout.That's impenetrable~
I have explored this issue for 2 days,and still can't work out.
Key CODE shows below:
#define ENET_IPADDR IPADDR(192,168,1,4)
#define ENET_MASKADDR IPADDR(255,255,255,0)
#define ENET_GATEWAYADDR IPADDR(192,168,1,1)
#define DEMOCFG_DEFAULT_DEVICE BSP_DEFAULT_ENET_DEVICE
void hello_task(uint_32 initial_data)
printf("RTSC ICMP IS CONFIG ing... PAGE-312\r\n");
int_32 error;
_enet_address address;//mac eq char[6]
IPCFG_IP_ADDRESS_DATA ip_data;
ip_data.ip = ENET_IPADDR;
ip_data.mask = ENET_MASKADDR;
ip_data.gateway = ENET_GATEWAYADDR;
//step1:create RTCS
error = RTCS_create();
if(error == RTCS_OK)
printf("RTCS_create is OK\r\n");
else
printf("Failed!!");
_task_block();
//step2:get mac to address
if(1 == ENET_get_mac_address(DEMOCFG_DEFAULT_DEVICE, ip_data.ip, address))
printf("ENET_get_mac_address is OK\n ");
else
printf("Failed!!");
_task_block();
//step3:INIT PHY
error = ipcfg_init_device(DEMOCFG_DEFAULT_DEVICE,address);
if (error == 0)
printf (" init ethernet device OK \n");
else
printf("Failed!!");
_task_block();
//step4:bind ip
error = ipcfg_bind_staticip(DEMOCFG_DEFAULT_DEVICE,&ip_data);
if(error == IPCFG_OK )
printf("Bind OK \n");
else
printf("Failed!!");
_task_block();
while(1)
GPIO_ToggleBit(HW_GPIOE, 6);//ToggleLED
_time_delay(200);
Project is compiled in IAR 6.30, MQX version is 3.7.
Original Attachment has been moved to: MQX_3_7_20170307ping_not_OK.rar
