How to get the exact time stamps on which the interrupt or the instruction is being executed in terms of micro/nano seconds?
himanshudoshi
When we feed multiple instructions as interrupt, I would like to know the time stamps on which the interrupt is going to be executed in the processor as I am using LPC Xpresso IDE on LPC Xpresso 54114 Board.
Kindly, help me out with this small problem. Demo code would be a great help.
Labels (2)
thefallguy
You can use the Cortex-M3/M4 cycle counter register in the DWT. Some information is provided here
embedded - Cycle counter on ARM Cortex M4 (or M3)? - Stack Overflow
or you can read the ARM Cortex-M3 Reference Manual, or the more readable Definitive Guide to the COrtex-M4/M4 by Joseph Yiu: The Definitive Guide to ARM® Cortex®-M3 and Cortex®-M4 Processors
himanshudoshi
Thank you very much thefallguy. I will look into it and get back to you.
