I am now trying to communicate with custom profile of BLE between two FRDM-KW41Z board.
I have a document called "Bluetooth Low Energy Application Developer's Guide".
The developer's guide has a chapter "8. Creating a Custom Profile" but it is not useful for me because it just explains the sample code, temperature sensor and collector's case.
What I want to do is "send 32bytes of data,
for example, from temperature sensor to collector" by modifying the sample code.
Could anyone give me suggestion or advise?
Tomo
I'm deeply sorry for the late reply on your problem.
Could you plase check the next threads?
Creating a custom profile using NXP BLE stack – Server
https://community.nxp.com/docs/DOC-328287
I believe that this might work exaclty for your needs.
Estephania
