INTERNAL ERROR: at line 7048: File not found: CODE\smm_pROM_xRAM.cmd (file: Drivers\56800\DSP56800.drv)
samzhang
It seems can't find the file with the special revision of Codewarrior V8.3 when click 'make' button. Is this the revision issue or my computer?
xiangjun_rong
Hi, Sam,
It seems that you do not select the correct the configuration, pls see the screenshot:
If it does not fix your problem ,pls show the error message screenshot so that we know the detailed error inf.
Xiangjun Rong
